I have a Hearthstone Equinox with approximately 4' of single wall black stove pipe between the top-exit outlet of the stove and the in-ceiling adapter to the double wall pipe that continues through ceiling and roof. The chimney has a serious draft that makes an in-line damper just above the stove mandatory. The draft is strong enough so that the the trash bag used to temporarily cover the open ceiling pipe snaps in and out so it sounds like a party noisemaker (the blowout kind where it unfurls when you blow!).
I have a slip section on the existing single wall pipe that was intended to allow me to collapse (shorten) the pipe so I could lift it up and off the stove exit lip to allow vacuuming of the stove interior after chimney cleaning and cleaning of the pipe below the damper, but the creosote buildup on the facing surfaces (even directly after cleaning) is enough so I can't twist/loosen the slip ring or its dance partner to shorten the pipe. I use a creosote-reducing additive, but the pipe issue has not changed for the better after regular use of the additive.
I'm looking for suggestions for a pipe setup where I can retain some form of damper and have the ability to collapse the pipe as needed, but where the collapsing/telescoping is specifically designed for ongoing movement in a creosote environment, as opposed to one-time adjustment when pipe is installed. TIA!
