Hi, Newbie here. We got this used Whitfield Advantage 2T pellet stove when we purchased our home. I am going through it now, just to make sure that everything is in order. Spent a lot of time, cleaning, I replaced a few things like motor gaskets, door seal. Also tested the stove, all seems to be working just fine right now.
There is one thing tho that I cannot comprehend. On the exhaust housing is a nipple which connects to the vacuum switch. How come the rubber line doesn't fill up with smoke and ashes??? Don't see how this creates any sort of vacuum..(???) Also, for testing purposes, I ran the stove (outside) with the rubber line disconnected. It keeps running????? I can select any heat setting and it keeps running just fine. It never stopped the auger like it is suppose to do. (???) anyone with some explanation would be really appreciated.. (posted some pictures)
Thank you
Thank you
