Need help with wood furnace in Vermont
kellygreen
9
Randolph, Vermont
Question
Please recommend a professional who can help me fix and maintain my Caddy Advanced wood (primary heat) and Bosch propane (backup heat) forced hot air furnaces and related duct system. I am in central Vermont.
Background
For a long time, I heated my 1,600 sq. ft. circa 1955 cape with a Newmac wood/oil combination furnace (I have forced hot air). My house was always toasty warm and all it took was 3 - 4 cords of wood (a little oil when I was away). I never had any trouble getting the house to 75 degrees (and hotter) with just a load or two of wood. When I fired the furnace up, either the wood or oil side, hot air poured right out of my ducts, particularly into the kitchen where the duct is closest to the plenum. I loved everything about the system, but had to replace it when I cracked the heat exchanger last year.
I replaced the Newmac with a Caddy Advanced wood furnace, and this year I added a Bosch propane furnace for backup heat. Now, I cannot get the house above 66 or 67 degrees and I can only manage those temperatures if I am home filling the Caddy's fire box religiously from dawn until dusk. The air coming out of my ducts is tepid and I can barely feel it. The problem exists whether I am using the Caddy or the propane furnances.
I am frustrated and need to hire a professional who understands forced hot air heating systems, can maintain a wood furnance and related systems, and who loves wood heat. The guys who installed the furnaces are not an option. Any recommendations for someone who can get to central Vermont?
I cant help you find a service technician, but so you have a barometric damper installed on your flues? Too much exhaust draft will send all your heat right out the flue.
Something has to be way off with this install...
