There have been a few hiccups in my stove install. The company is coming in two weeks to finish it off. I wanted to get everyone's opinion to see the best option to move forward.
One of the issues is that they forgot to order an EXCEL liner top support. They continued and installed the EXCEL liner and wall path through. They put on a temporary (Integrity) top plate to seal everything off. The top plate wasn't trimmed as they plan on reusing it.
While on the roof today (sealing it up from an antenna mount I removed) I decided to take a closer look. The EXCEL top support claims to be 4.5" tall (needing that much liner to mount to). The temporary top support is just under 3". There is zero room left from the temporary top support, so I'm assuming they are not going to have enough space to install the top plate correctly. I mentioned this to the installer and he mentioned they save sections from the liner and can extend it (I guess just 2" or so?).
Given this situation is it even worth putting on the EXCEL top plate? Will the 2" extension be strong if riveted into place? My preference is to have the EXCEL top plate as it seems to better protect the liner from the rain. The current one has some large gaps around the liner. BUT, if modifying the liner at this point is just going to make it worse I will live with it.
What is the best option here?
I'm kind of pissed they didn't bother to look up that the top support was 4.5" and just make sure it was long enough, to begin with. Other issues have been a result of not measuring accurately or reading the manual from this specific liner. Does it matter? Am I being too picky?
icc-chimney.com
(broken link removed to http://icc-chimney.com/c/icc/file_db/docs_document.file_en/L-II-A_2017-05.pdf)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262208-e47ac5912939d118d97b3c44728201a9.jpg?hash=9qzPsIzEUS)
EXCELiner – ICC-RSF
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262215-46a8e623eaae062e1b6e3608a2461a05.jpg?hash=uA-HfckarE)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262216-6ad55ab05e3bf2e6135b91ad87b9d87c.jpg?hash=kPZdqBDeT8)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262221-46220cfa82f61bc4d8f58036afefeed9.jpg?hash=uLW4vv9B1C)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262222-5339aab71237c17f763694e0ea87c7b8.jpg?hash=yqIPicrJxQ)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262441-d1e6e9824e07cbd558115a8e6ea8c54c.jpg?hash=Q8YZhL8_ui)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262477-d10675efe68130f6e465226030922b0a.jpg?hash=azYGmcsuqk)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262478-12cdbb258bf6c8c6b67df4760fa72084.jpg?hash=Uf-5oqlYaU)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262479-83efcbe103533dbd1d830704dc2c2f2f.jpg?hash=5vQL5VPSG2)
![[Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support) [Hearth.com] Need Opinions on Finishing Stove Install (Liner Top Support)](https://www.hearth.com/talk/data/attachments/262/262480-40af2e32111ee9b889d172ce65a868b7.jpg?hash=DKW04lEU52)
