Hi Folks,
We're planning a finished basement and will be installing a wood stove. At the moment, i'm trying to figure out the best way to run the chimney. We have a prefab chimney installed for a fireplace on the first floor, and ideally i would like to be able to use some of that structure to support the new one.
Here are a few shots of the location we're planning for the wood stove. In the first shot from the basement, you can see the floor joists that extend out to the cantilevered chimney base (obviously we'll be moving some of the wiring and heating ducts).
(broken image removed)
Here is the outside of the home from the other side of the wall ( i was basically standing between the window and the tree you can see in the first pic)
My basic question is whether or not i can either squeeze the new chimney into the existing frame or just extend the existing frame to wrap the new one. My other question is whether or not having two chimneys this close together would cause any problem. I'm assuming i can't 'Y' the chimneys together to reuse the same stack to the roof...correct?
Thanks folks!
Thanks folks!
I'm still working on my terminology...haha. Is the thimble that bushing like thing that supports the pipe through the wall?
