Need some advice stove replacement
corey21
2,249
Soutwest VA
Thinking about getting a new stove just don't like the one in the house. Got my eyes on the NC 30 would this be a good replacement?
That stove you got is a pretty good sized stove, are you having issues with it?
Its a 3.24 cubic foot box. 18 1/4 x 20 1/4 box
I have had issues with it from day one i added more chimney also it just seem like a bad brand to me.
Tells us some more details as what kind of chimney , whats its height?
Whats the stove doing thats causing issues.
Do you have a stove top temp and a flue pipe temp? Is it hard to start? what kind of wood are you using , how long has it been cut and split?
Can you post a pic of your setup?
We should be able to help if we know more.
I have a 12 foot chimney draft is good i burn 2 year old red oak and hickory. But my burn times are about 4 hours and that's with a good load. I have tried burning east west north south it is the burn times that really bother me.
Stove top run about 500 measured with a rutland thermometer. My flue temps are lower then what you all see but it has a firebrick in the baffle that can be removed. But when i remove it my stove top temps are low.
The burn times is the biggest issue.
oldspark said:
Can you turn the primary air all the way down or mostly so?
Yeah i can run it with it closed at 550 and get a great light show.
oldspark said:
No leaky door gaskets?
Nope done a cigarette test on the flue and around the stove and door.
Burn time is a relative and subjective term. If you are looking for say 4-5 hrs at a continuous temperature of over 500F, the stove should be able to do that. What are you seeing? What size splits are you burning?
I reload at 250-300 stove top with small splits i get 2 hours with big ones i can only get 4 but 5 is pushing it. i wake up a lot in the mornings to find a cold stove it is starting to get to me.
How much of your money can we spend?
Well i would like to keep it under 1100 if possible.
Well with that budget look for a nice used cat stove if burn times are your biggest concern...bigger the better.
HotCoals said:
Well with that budget look for a nice used cat stove if burn times are your biggest concern...bigger the better.[/quote
I don't really want a cat stove.
If I were you I would go to a local dealer and see what their recommendation would be. While its great to have a rep from the manufacturer answer your questions via phone, email or even here, its a whole lot better to have the person who sold you the item standing right in front of you.. Boy what I wouldn't give!
Jason
I looked at home depot and they have stores in my area. They have the nc 30 right now for 649 I really like the nc 30 and it get gets great reviews. I have went to there stores before and seen the 30 they have just never checked it out before.
If you would be happy with 6-10 hour burns (depending on which stove) and decent output ..a tube stove would be fine.
The NC-30 would fill the bill...most say around 8 hours of decent heat...usually enough coals to fire off the next load.
I was just suggesting you buy from a local source, I see a few people talking about having them shipped in from other stores ETC.. Seems like a great deal for that stove, Englander stands behind what they sell.
Jason
I would hold off on getting a new stove those US stoves are EPA certified just like all the rest so if you havent learned to burn this one your gonna have the same issue with a new one.
Do you rake your coals forward?
How many splits can you load? East west should get you a longer burn.
Do you have a manual pipe damper installed as you can experiment with the pipe damper to give you an indication if your draft is too strong.
Thats a really good deal on a nc-30 for $649 but expect the same issues if you dont figure out the problem. As I am sure the stove you got with all the testing and certifications stoves have to go thru can do better.
That would be really tempting a NC-30 for $649.
I have tried every different method for getting longer burn times. I know i have good draft cause i can close it down and have nice secondary's. Also the tech support with us stove is awful.
Then I would jump on the $649 NC-30 Deal, Wish there was a deal like that when I bought my stove.
Make sure its not a NC-13.
Where... where?!!
Edit: Nevermind... it's a 13.
They have the 30 for that price.
(broken link removed to http://www.homedepot.com/h_d1/N-5yc1v/R-100291302/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053)
