I posted this in the wood stove forum and was told I should ask here as well to get opinions and options for pellets, so here goes...
The wife and I just bought our first home and are learning the hard way it seems. The house has electric baseboard heat so we were hoping to burn wood to cut down on some of the costs of heating. I had the chimney cleaned and with the advice of some on this forum I took the top plate off of the insert and it revealed that the insert has no piping from the top of the stove/damper to the chimney and the top and sides of the stove are covered in what I am guessing is creocote.
I have asked around and have been told that this stove probably needs an 8" chimney liner (costly). My thought was to get a liner this year and potentially a new insert next year, but the the dealer I talked to advised against that since new stoves use 6" pipes.
The house is a 2200 sq foot bi-level (1100 up and 1100 down) with 8' ceilings (drop ceiling in the lower level). Both levels are finished, lower level is about 3' below the ground level. Guest bedroom, 2nd bathroom, laundry, family room on lower level (all rooms have individual thermostats to control electric heat on/off), main level is living room, dining room, kitchen, bath, bedrooms. Upper/lower level are joined by split staircase at the foyer. Fireplace is on an exterior wall adjacent to the garage below the upstairs living room. Just moved into the house about 45 days ago so we don't have wood in place, but have access to seasoned split wood from a friend who cuts/sells for a living. Generally, the wife and I are home in the evenings and on the weekends and we plan to spend most of our time in the winter in the upper level. So here are my questions...
Do I spend the money to have the current (80's) stove retro-fitted with an adapter and chimney liner?
Do I try to buy a new wood or pellet insert and liner or
Do I buy a smaller stand alone wood or pellet burning stove to put on the upper level?
Fireplace dimensions are 36w x 28 h x 18.5 deep. The width and height are at the front. The box tapers slightly to the back.
I am a new home owner and new to wood and pellet burners so any info and/or advice would be greatly appreciated.
Require power or generator if power goes down.
