I need to build a 3 1/2 inch spacer on my hearth so that the insert will be at the same height as my heatalator. The heatalator has a 1 1/2 in gap for air on the bottom and a 2 inch tile base making it 3 1/2 inches higher than the hearth in front of it. My question is- can I simply frame up 2x4's and plywood covered by hardy board and tile? or will the insert produce to much heat for this? If so what would you do to build the 3 1/2 inch space?
Kind regards,
Dave
Kind regards,
Dave
