New Anemometer $16 for checking CFM and temp works good!
Don2222
9,273
Salem NH
Hello
This is cool!
https://www.amazon.com/gp/product/B072HN7RMY/?tag=hearthamazon-20
This is a very necessary tool for any forced hot air heating or cooling appliance!!
You can test all the heat levels on the front of the pellet stove!!!
So I just measured the diameter of the little fan blade opening on the meter as about 2.7 centimeters which makes the radius 1.3 centimeters so that would be about 0.013 meters.
Now the area is Pi x Radius Squared = 0.057 Meters Squared
So the CFM = Area in Meters Squared x feet per min,
So CFM for the Englander Blower I measured on the exhaust flange is:
CFM = 0.057 x 1855 = 105.7
I know the Englander blower specs are 85 CFM so I am close but I am not sure where it is measured and my approximation of the area of my meter may be off also but for $16 I am not complaining!!!
What do you guys think???
Any more info on this meter for better CFM calculation?
Pic 1 - floor register with Harman on low flame!
Pic 2 - brand new Englander 85 CFM Exhaust Blower on Venting flange for a baseline to compare an old or dirty stove!
Baseline Feet Per Minute measured here is approx 1855 ft/min
  • [Hearth.com] New Anemometer $16 for checking CFM and temp works good!
They are fun,I have several cheep ones like that,use them for wind measurements when shooting.As far as cfm,blower motor cfm is measured right at the motor assembly,usually within a test duct,the size of the outlet,or the size for the particular installation.Measuring at the stove outlet will be representative,as airflow goes through turns,bends.Also,reading higher is very possible,because if airflow duct/passageway is downsized,speed will rise.That is why ductwork is usually stepped down,the longer the run in a house.Hope this helps.
Reactions: Don2222
Don't forget you also have to take the efficiency of the fab itself into account, that will account for some differences too. I used to work for an industrial fan company many many years ago, the testing involved in fan design is really interesting. Sometimes just having an idea of performance is satisfying -
