ecocavalier02 said:i did the same thing in my floors sept i made my fittings and stuff at the shop nice to be a tin knocker. ill have to take some pics. and post em. they do work very well.
Thanks--please do!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
hotprinter said:Jim41 said:Nice set up! I'm interested in the floor vents you installed. Could you provide the brand name and model number? It may be what I need to get some heat moving to the the second floor. Thank You Jim
REPLY:
We just got them at HOME DEPOT. We built ducting to completely surround them so there is no path to the floor joists. For 30 years we could never get the heat from the basement upstairs, now the whole house gets the heat.
rustynut said:Inspector told me that I couldnt heat a room below
my stove because of code but didn't say anything about using something like that.
summit said:not as ugly of a stove as I remember most BK units being... looks good!
i, too, would like more information on how to get heat from downstairs to upstairs and still meet code. do explain these fire dampers. are they always open like the ones the op is using and you just close them manually in the case of a fire? thanks.hotprinter said:Hate to burst your bubble. But a register with duct hooked to it between floors does isolate it from the floor joists. But is not code and does not slow the spread of fire from the lower level to the upper or vise versa.
That is the purpose of the fire damper. It is to create more time for the fire to get between floors, rooms, etc, thus giving more time for evacuation.
REPLY:
It meets code in our area. Our codes may not be as strict (in rural Alaska) as they are in the lower 48. Check codes in your area before any remodel. Can you post a photo or website explaining a fire damper please.
Thanks
lethal dose said:do explain these fire dampers. are they always open like the ones the op is using and you just close them manually in the case of a fire? thanks.
