hello everyone
i posted here a few years ago about boiler options. that house was slab on grade (both house and large garage) and used an oil boiler. after asking and reading here i came to the conclusion that i would not get my money back because i knew i was not going to stay there long enough.
well now i am in the final steps of buying a new much bigger "forever home". but this home is heated via forced air propane. which i know is going to kill me next winter as bad if not worse then the oil has killed me the last 3-4 years.
it is a modular home built on a very nice poured concrete foundation with foam insulated walls but no studs or anything. it is a ranch with a loft. i believe it is 2x6 construction and was built in 2005 so it should be decently insulated and has decent double pane windows. however in the great room there are a lot of them!
in the unfinished basement it looks like the previous owner had a large soapstone fireplace thing plumbed into the heating run. it was taken out when they left the property and the property is bank owned now so no idea on previous heating costs.
so i have two questions.
1. what is the best course of action to heat this place with wood/coal/pellets. since the basement is unfinished and its a ranch could i do radiant in between the joists and call it good or is a HX in the plenum of the existing unit the way to go?
2. how far and what elevation can radiant heating water be pumped? the home sits on 15 acres and has an unfinished pole barn that will eventually be my shop. its a good 200-300 feet from where i would most likely put a boiler shed and at least 50 feet lower. i will eventually finish this pole barn and pour a slab with radiant pex just trying figure out if i can tie into the first system or if it will need its own due to distance and drop.
