New house we are buying with VC insert
Tracks74
54
Milwaukee, WI
We have an accepted offer on a new home with a Vermont Castings Montpelier insert. My goal is to heat the 1800 sq foot home with wood primarily. The VC is non-catalytic and I assume is undersized and short burn times.
Given the dimensions, do you all have an insert you would recommend or would you you remodel the brick work for a catalytic stove?
Pics if the fireplace are from the home listing below.
New house we are buying with VC insertNew house we are buying with VC insert
It might be worth trying the VC insert a try for a season to see how it works out. If the house is well insulated it might be ok. If looking for a replacement we need the fireplace opening and rear dimensions plus the depth. No need to change the brickwork for a cat or non-cat stove.
Reactions: Tracks74
Sounds good BG. I know I have time on my side. House comes with 3+ cords of precut/split wood and time to experiment.
Sweet. It's a good looking insert.
My friend has that stove and his house about the same square footage though it's a two story home. It does most of the heating and he loves it, it's also a nice looking stove.
Reactions: Tracks74
It maybe worth pulling the outside cover to see if there's a block off plate installed, and what type of liner system you have, also an inspection of the chimney / liner and unit is a must before burning.
I burn the VC Montpelier in a ranch that has about 1,800 sf on the main floor. It keeps the LR, DR, kitchen, & study in the low 70s, the 3 BRs in the mid to upper 60s. My ceiling insulation is pretty good, the walls are 60 years old and settled. I have an internal chimney with insulation above the heated area. The insert gives me good 6 hour burns and enough embers to restart up to 8 hours. That is with 3 yr seasoned red oak well packed. I have a second stove in the walkout basement that I use on really cold spells or when we are using the family room down there.
I'm quessing that your climate is a little colder than mine so a lot will depend on the insulation.
If you have questions about the insert let me know.
KaptJaq
