Hi, I bought a Jotul Oslo which replaced my 15 year old Vermont Castings Dutchwest catalytic (large) stove which I used for 3 seasons. I could pack the Dutchwest full, close the damper and it would run all night leaving a nice coal bed in the morning.
1)Can I do that with the Oslo?(the manual says to use 3 to 4 pieces at a time :'
2)It seems to run pretty hot and gets even hotter when I turn the air control to the lowest setting. All flames are up top and look pretty scary and furious. The top thermometers are at 525. Can I fill it up? I have not put in much more than 4 to 5 smallish split pieces of ash or elm.
3)Does it run more efficiently when its really hot and the air lever is all the way left or is it better to have it open 1/4 to 1/2 way?
I worry about overfiring the stove. The Dutchwest was impossible to overfire when running the cataylic converter with the damper closed.
Thanks a ton in advance, this is a fantastic site which I plan on visiting often, I already am running hotter and I believe it is putting out way more heat than the Dutchwest ever did and thats with less wood.....
Bill
Bill
