New living room.building pictures
Hansson
Hello burners
I building a new living room. 50 m2
Follow the link for some building pictures.
The insulation in the walls is 24cm,Underneath the floor 30cm. 30-60 cm in the roof
Underfloor heating from Uponor.
(broken link removed to http://picasaweb.google.se/725hansson/Bygge?authkey=Gv1sRgCPfa87rQgMKeUA#)
Have a nice day!
Hansson,
Very nice. I've never seen framing like that, is it standard practice there? Those trusses are pretty massive.
You've basically got a header the whole length of the wall.
Very interesting.
That looks strong to hold a lot of snow. Fantastic amount of insulation. I'm very impressed with the job Hansson. Enjoy!
Hansson said:
PapaDave I think it standard practice here.
~*~vvv~*~ what is the froswall?
the block wall under the room's exterior walls.
It`s lecka walls.The insulate some. I wanted more insulation around the walls but it never happened.
(broken link removed to http://www.e-weber.com/en/activities/expanded-clay.html)
Maybe I put some foams on the walls later
Under the ground around the block wall there is insulation for the ground frost
Looks like a ton of work there but very nice! Hope that works out great for you.
Thanks for posting Hanson. That looks like it will be a very nice addition. Please keep posting updates as the project progresses.
What is the age of the main building? What temperatures do you see in winter?
Now the floor heat is ON :-)
I got a 4-way mixing valve that first take the return water from the radiators in the main building.
If that is not hot enough the valve takes water from the top of the tanks.
The automatic heat regulator is a Thermomatic CBJ RS from http://www.termoventiler.se/
(broken link removed to http://translate.googleusercontent.com/translate_c?hl=sv&ie=UTF-8&sl=sv&tl=en&u=http://www.termoventiler.se/index.php?sida=produkter&undersida=thermomatic&produkt=thermomatic_cbj&prev=_t&rurl=translate.google.se&twu=1&usg=ALkJrhghnK4rb8ERJLegKB9D6lfr2TqIYg)
Some new pictures.
The installation is not complete the pipes have to be insulated and some wiring is left.
Have a nice day
That is very impressive plumbing. And the crimped joints, I imagine that saves a lot of time over soldering all of them? Nice work man! Bring the cold!
I see you chose RoXul insulation. I just reinsulated my entire house with this stuff. Did you find it easier to work with than traditional fiberglass? I did.
A small update.
I have started to patching the walls and the roof have got it`s first layer of paint.
I hate the patching :shut:
The windows have arrived but I have not install the yet.
Have i nice day
Looks great Hansson. Are the windows double or triple glass? I agree with the patching. All the sanding and dust is terrible. The ceiling paint looks nice. What are you going to put on the floor?
Love the red exterior!
Enjoyed the pics - nice work.
It`s triple glass. U value 1.0 i think.
Double glass is not used here.
On the floor it becomes an oak laminate floor.
In the roof I will have 9 9w LED Spots. And 1w leds over the windows
Windows will be installed today :-)
Can you provide a link to the type of LED spots you have?
Looks great! We're in the middle of renovating an old one-room school house, so we can appreciate the amount of work that went into your addition.
Keep up the awesome work!
Very very nice. Don't forget to update this thread when the room
is completed and furnished. We love pics!
