s Thank you for all the tips and input!
So far, my theory is this: Hot Long burn overnite with oak, small fast burns during day to keep coals and get pipe temp up, however, that chunk of rock holds the heat well as said to be the character of soapers! It is a world away from the operational aspect from the catalyst stove to this, infact it is taking some getting use too. I dont know if it was the way I operated the catalyst stove, or what, but in 2 days of this stove, I have had more conistent 400+ degree pipe temps than the Dutch. I had really inconsistent temps with that stove and backpuffing regardless of fuel in it. IT did the job for 6 years, and had Inot come across the deal I did, it would still be in service instead of being prepped for sale.
Helps for you all to know the layout of the house, and why I chose a 2200 sq. ft. stove to beging with. House is Cape Cod/bungalow style, and "open floor plan" is not us! Numerous doorways and specific rooms, however the saving grace is that the main floor is accesible in a complete circle with all given entry ways which makes for good air flow. With that said, the hearth and burner are in the SE corner of the house main floor, living room in NW corner, Master in NE corner, so all main functioning space of house is NOT in this hearth room which serves as our library. The second floor is all open with knee walls, so we ducted piping from library second floor, and force heat in via a 210 CFM exhaust fan, and now with this Equinox, have some duct access to heat the semi finished basement with the same method now, just have to work out the details and find the correct fan.
IF this stove was centrally located in this small of a house, there is no way I would have got it, but since it lives in a remote location, and goal being keeping the furnace off as much as possible every winter, I went with a stove (to start with) 2x the rating of our SQ. FT.
that should make it a bit more clear, and now you all have a better lay of the land!
Added pic with flue thermo about 375ish and the unit itself! Has a load of Maple for daytime...oak at night.
In the pic, note pile of build up black ash to the right, that is what came out of about a 5ft. section of single wall when scraped after removal of the Dutch. That is about 6 weeks of 24/7 burning. It looks like that usually after 4-5 months of burning. The dutch took quite a bit of babysitting, but has done its job, this year it just didnt seem to be working quite right. Even after a new catalyst, and gaskets all the way around the beginning of last year....so there you have it!!
