Hello. I am a basement dweller, posted about 2 months ago with "which stove" type questions. Anyway, about a month ago I had a Enerzone Euromax (almost the same as the Drolet-65)Installed in my basement. I just fired it up for the first time yesterday (other than the quick test after the install) and am trying to dial everything in.
As I mentioned in previous threads, My house is 2000 sqft with a full (unfinished) walkout basement. My office is in the open, unfinished basement and I spend 8 hours a day down there. I need some suggestions.
I currently have the stove running on "thermostat mode" with the intention of keeping the basement warm while still pushing heat into the open concept living area via an open stairwell. The stove sits directly in front of the open stairwell (about 15 foot away). I decided to opt out of the "plenum kit" this winter to see if I can get the stove working to my satisfaction without it. Not sure that I will be able to get enough heat upstairs without it. Suggestions on moving heat to the upper level before it gets sucked up by the exposed concrete walls?
I am looking for suggestions on stove settings as well. I have read the manual, but this thing has so many settings it is very confusing. Currently it is running on the highest combustion setting and also the highest fan speed. It is EATING pellets like crazy. I would say 3 bags in 24 hours. Outside temp is 46, basement is 73, and upstairs thermostat for forced air propane burner is reading 69/70. Again, this is with the stove cycling on thermostat mode and highest combustion rate, to keep the basement at 73 yet get heat upstairs. Goal is to supplement the propane forced air with pellet heat.
I do have the stove thermostat on a 30 foot wire so I am able to move it to different areas of the basement.
Interested in hearing from others with the Enerzone or Drolet... Specifically with a basement install. What works and what doesn't? Should I tweek some settings to get my desired results or make current consumption levels better? Can/should this stove be run full blast all the time? Should I run it on manual mode at a lower combustion setting? Not really sure where to start. Kinda scary that it is only 46 outside and this stove is running constantly just to keep the basement at 73.
Thoughts, suggestions, opinions???
Thanks
Jeff
Thanks
Jeff
