Need some advice please..
As a kid we had a hearth built in our older brick house. The brick hearth is about 5' x 5' x 2' and had a wood heater with blower that had a side door and an ash pan on the bottom. It was a large heater and would hold I think 24" firewood we cut (several pieces). I don't remember the brand or much more other than the pipe went out the back of the heater into the side of the brick wall where we built an exterior side chimney with a flue pipe in it. The chimney is about 13' tall with a 8" flue. The right angle flue started about 3' off the ground inside the chimney so the actual flue is about 10'.
The house is about 2000 sq-ft with several bedrooms in back of the house (other end). I just remember at full fire that heater would heat pretty much the entire length of the house and run you out of the room it was in due to the heat. I am looking at adding a wood stove back to heat as much of the house and interior rooms as possible. (I know side rooms may take fans of some sort to move the heat). Will these modern heaters work with a right angle flue? I only see top pipe stuff. I don't know about all these 'cat' heaters as well; all I see is numerous reviews on how they are problematic if not setup and fired up perfectly. I was looking for heater with a large firebox that works with a right angle flue. I have looked at the Green Mountain 80, King 40, and a Lopi large cast iron heaters. Any ideas or recommendations would be appreciated.
Thank you for your time..
