Hi All,
Been reading on the forums for a while and this is my first post. Found a lot of useful information and figured this was the best place to ask.
We bought a 3000sq ft house last November that is a real fixer upper, energy audit couldn't get a reading on the blower door test to give an idea of how bad it was.
It's a large space and has multiple heating options going on. Forced air oil furnace, separate pellet furnace tied into same ducting, just installed Enviro Mini pellet stove in the kitchen and a Large VC Defiant in the living room.
We are looking at replacing the wood stove and are thinking about best options.
Main reason is to get a more efficient stove, the VC is big and produces a lot of heat but needs to be tended very regularly and uses a lot of wood. Don't really get a full overnight burn either. Maybe some warm coals if I absolutely pack it.
Any suggestions? Hoping to not spend over $2k if possible.
Also the chimney that services the wood stove also services the pellet furnace. It is a newer brick clay lined (8*8?) chimney that runs straight up the middle of the house. Draft is really good.
However it also services the pellet furnace. We aren't having any issues with backdraft or anything like that but obviously a new build would not have this scenario.
Would we be ok installing a new wood stove replacing the old one or would we have any issues with the chimney servicing two systems? Have seen chat about installing an insulated liner when you install a new stove but don't see how we could have two liners down the one chimney, or am I wrong?
Sorry for the long post but any help or advice would be appreciated.
![[Hearth.com] New Stove options and Chimney questions [Hearth.com] New Stove options and Chimney questions](https://www.hearth.com/talk/data/attachments/284/284232-017b475261cdd1e4950fc4348890587a.jpg?hash=2JNhyzN73k)
