We're really excited to get started on this project but after some research, we could really use some guidance to narrow it down. So, thanks in advance for your thoughts.
We have a 1440 sqft home not including the basement and the attic. For the record, it's already tighter than the blower door we did 2 years ago that measured 8.5 ACH50; and we're going to seal up the sill plates before we're done, too. But I digress. The location for the stove is in the basement where the oil furnace used to be. That room is ~ 625 sqft. It's a daylight basement with windows and a cellar door to daylight. The brick chimney is in the center of the house and has a clay pipe flue that is (probably) as old as the house. There are no other utilities using the flue. We will get the requisite thorough cleaning and level 2 camera inspection by a NFI+CSIA professional sweep. The same firm will also install the stove.
We're installing the stove to provide auxiliary heat. Otherwise, we use a combination of mini splits and a ducted heat pump that work great. But when it's below zero it could be more comfortable and also, we have no backup in the event we lose power.
So we're all in on a woodstove to solve fo this - but we have a few concerns.
1) The first is that we'll be superheating the basement with too little heat getting to the 1st and second floor. Which stoves will allow us to control the heat output the best?
2) We're stuck on the trade-offs of catalytic vs noncatalytic stoves. I suspect that the money we save with the current tax credit will go right back into a maintenance contract of a catalytic model
3) What is the least expensive way to get hot air into the upper floors from the basement? just opening the basement door and waiting for the heat to rise doesn't seem like a good bet. also we want to avoid a powered solution because the design should work well when we lose power.
4) If we need makeup air what if anything are the issues we should be aware of. Just crack open a window?
5) The flue will be 35' long. The attic is part of the building envelope.
sorry for all the questions - but any and all thoughts are very welcome. thanks!
![[Hearth.com] new wood stove install in a 100 year old kit house [Hearth.com] new wood stove install in a 100 year old kit house](https://www.hearth.com/talk/data/attachments/280/280071-aaa2ef7b820c4134bdafa7100c234cc5.jpg?hash=zPGFaTPmQ3)
