Our Vigilant from the 80's had one too if I remember properly, but I don't recall it actually working that well. Since BKs actually works well I guess I assumed it was of a different design but really have no idea.The thermostat has been around for ages; My BIL's VC Resolute III, circa 1980, has one.
You mentioned 500ºF stovetop earlier, I wouldn't call that low and slow... that is about the max I have ever run mine at so far!Keep in mind I am deliberately burning as low as I can to prolong the burn. If I had turned the air up more I would have more temperature.
I have yet to see documented proof that Blaze Kings burn as long as they say they do. It's not that I don't believe it, I just want to see hard data.
What type of wood are you burning?This is 16 hours into the burn. Plenty of btus still in there.
Here is 12 1/2 hours in. Lots of big charcoal bodies and flames. 38 outside 73 inside. The cat read 400 and the stove top reads 200. I probably had it set a bit too low but it provided me the heat I need. I'm going to bring it back up to temperature then shut it back down. Keep in mind I am deliberately burning as low as I can to prolong the burn. If I had turned the air up more I would have more temperature.
Copy.NVHunter, there are many variables affecting burn time. The same stove in a leaky or large house is not going to get the same burn times as when it is in a tighter smaller house. Same thing with wood species being burnt, draft strength, etc..
Cat at 400 would mean it stalled, right? One nice thing about the BK stoves, I've never stalled the cat. Tall chimney helps that!
Wow that's what my nc30 looks like after 6 hrs on low with Oak.Well this is the 26 hour mark. There isn't much usable heat coming off the stove, but it kept my house between 71-75 degrees inside temp the whole burn. 38 degrees outside 71 now on 2nd floor thermostat. You can use your imagination it would obviously keep going to some degree if I let it go, but I'm going to reload on the nice coal bed.
It was a little windy today and my house isn't air tight. It's true a Blaze King would do all of the adjustments for you. I gave it small adjustments every 4 hours or so. All things considered I would call it a successful low burn. The wood was 2 year seasoned white ash.
Nice! What stove top temps have been maintained in this period?
Wow even I would have doubted the stove would have had good coals left still at that mark. I'd really like to try and see what kind of long burn I can get but looking at the forecast next week (I have it off) looks like I won't get a chance. I'm going to need more heat. Maybe towards next weekend, but hard to say. I'm even a bit nervous today how warm the house will be when I get home around 7pm since my pellet burner is getting clogged and starting to burn dirty I have it on the lowest setting just limping today. Loaded the stove up at 4:30 but still using the short pieces (13") I have indoors, stacked 4 ecobricks across the front to fill in the extra space from the short pieces. Suppose to be close to zero tonight with negative teens wind chill so I need to bring in and start using some of the bigger pieces...Well this is the 26 hour mark.
It really doesn't matter much. My house is warm and I am not going through any serious amount of firewood. What more is there to care about?
I remain amazed at how little I am burning with the Ideal Steel.
Like tonight: currently 19 degrees @10:45pm and I'll soon be loading for the overnight after adding 3 splits at 4pm.
Inside temps varied from 81 to current 75 degrees.
Your loading schedule sounds almost identical to mine. I load up the stove at 5-530 in the morning and then a few splits at 530 when I get home from work.Pretty full load last night, engaged CAT, set draft to just barely open.
Stirred the large coal chunks this morning at 6am and ran wide open before adding 3 splits.
Came back @ 2pm, cleaned out some ash, added a couple of splits and set CAT.
Added wood @ 7:30pm and “topped off” at 9. Doing that again at 11 and we will be set for the night.
Mostly dry, dry locust and one big hickory chunk tonight.
