Hello from Texas. Long time lurker, first time poster. I'm planning to replace a Heatilator Mark 23 factory fireplace in my 1970s single story home and would appreciate a review of my plans to see if they look reasonable before I start.
First things first. I have a good supply of 2 and 3 year old pecan and oak which is split and stacked under cover.
Here's the existing fireplace view from inside and on the roof. The fireplace does work, but provides precious little heat.
I plan to remove the whole thing - hearth, fireplace and chimney and replace it with a modern wood stove. The desired result is to use the stove for supplemental heat and enjoyment of a fire. The 2,200 sq ft house has heat pumps, but they are older and don't perform so well when it's much below freezing. And, we do lose power periodically. I've got an endless supply of wood on site and enjoy cutting and splitting.
I am looking at a Vogelzang VG2520E-BP which I can get at NorthernTool for $900. Product manual is here. In addition to the stove, I think I need the Duravent UP kit (6DP-KTUP), a Duravent adapter (6DVL-AD), Duravent DVL telescoping connector (6DVL-68TA), and 3 or 4 pieces of Duravent chimney (6DP-24SS).
I'm planning to build a hearth with 3/4 plywood covered by 5 layers of 1/2" Durock with tile on top. Looks like each layer of Durock is 0.39 R value and the stove manual calls for an R of 1.4. For the rear wall, I am planning to do a single layer of 1/2" Durock covered with tile. The hearth footprint will be a little bigger than the existing one. I think I can meet the rear clearance and have a straight shot up without any elbows.
Any help or input is much appreciated!
