Hi all,
I am in the process of framing my ZC Heatilator Constitution wood-burning fireplace just installed late last week. I made a new header placed across the stand-offs of the unit as instructed by the manual. However, I measure 1 1/2 inches clearance between the header and the (square) chimney air kit (for outside air) where the chimney pipe connects at the top of the unit. Is this an issue? If so, what can I do to resolve it?
Note, the clearance I measured between this header (including any vertical studs connected above header) to the actual chimney pipe protruding from the chimney air kit is no less than a 2 1/4 inches. The manual states that 2 inches between combustibles and chimney sections must be adhered to.
Any professional advice is appreciated,
Kevin
Kevin
!. %-P Rick
