No upper augers turning
Mike071961
1
USA
Hi all. New here but have had 2 pellet stoves for years. My Englander 25-PC DV upper auger will not turn. I tried the lower auger wires to the upper auger and it turns,so I know the motor is good. I'm thinking a bad vacuum switch? Just not sure how to test it/them. Any help? I also have a new motor (just in case,lol) but really am leaning towards a vacuum switch. Help please!
Do you know that the top motor does not turn constantly?
If you do a topic search on " My Englander pellet stove top auger does not turn " either here or use your web browser it will direct you to just about all the information you would ever need on this particular subject by those of us who have experienced the same issues.You will be surprised on how much you will learn about your stove.
Testing them temporarily is easy. Just take the two wires off the vacuum switch and jump them together. One switch at a time. You might want to check the hopper switch to along with the vacuum hole inside the fire box to make sure it’s open and clear along with all the tubing.
Reactions: Ssyko
