When you burn a non-cat stove with secondary air tubes, I gather that you need to get the firebox up to around 1000 degrees for the smoke to light-off.
When the secondaries light-off, is the heat from the secondaries enough heat maintain the heat necessary to keep the smoke burning?
If secondary burn heat is enough to keep the smoke burning, then can you shut down the damper (I assume primary and maybe secondary dampers) such that you have a smoldering fire with very little flame - totally relying on the secondary burn to maintain enough heat to burn the smoke from the smoldering wood. Does this work?
The reason I ask is because I have a catalyst combuster stove, Woodstock Keystone and it will burn the cat brightly on pretty much smoke alone with a few red embers and no flames for a clean low burn.
I also have an Englander 30 non-cat stove that will get installed this fall. If the above is correct, then one could get a smoldering low burn while maintaining the secondaries (until the wood goes to charcoal and no more outgassing) not unlike a cat stove. The only difference is you have to get the stove up to a higher temp on a non-cat to light-off the secondaries, but then relying on the secondaries to maintain the heat necessary to keep the burn going, turn down the damper and let the stove cruise for a clean, long burn. Instead of a glowing cat burning the smoke, the secondaries burn the smoke.
We talk a lot about shoulder season burns being very easy to do with a cat stove, but I'm thinking the same is possible with the non-cat secondary tube type stoves like my Englander.
Have I got this correct or am I way off base?
Thanks!
Bill
Thanks!
Bill
