A runaway stove is just a stove that is getting hotter than you want it to despite all normal efforts to cool it down. The stoves are designed to prevent the uncontrolled temp from climbing too high. It is possible, though unlikely, for a stove to runwaway beyond a safe temp. This can lead to a chimney fire, it can lead to stove damage, it can lead to burning your house down. Way to hot runaway stoves can happen for a variety of reason including poor stove design, high energy fuel load, leaky gaskets, other air leaks, plus maybe more. All EPA non-cat stoves are runaways to some extent. You can not close the throttle off so you can not prevent these stoves from getting hotter than your predetermined desired temp unless the temp you want is hot.
So you don't have full control but with experience you can know what to expect. Might as well get used to it, this operational limitation leads to lower emissions since a hot stove is a clean stove. Clean stoves are here to stay.
