North Country Softie's Updated review
Phil Do's fire.
598
Hyde Park, NY
I reported on November 17, 2107 a review of these pellets. Here is an update,
This is the first time since I have owned my stove in 23,000 + hours that I had to make changes!
  • Excessive moisture in pellet, open bags for 3 days helps
  • Pellets are very small, blocks off air holes in burnpot
  • Turn down feed rate if possible, I slowed the burn rate 21% .
  • Lowering the burn rate also lowered heat output, stove runs much longer
  • Increase combustion blower speed
  • Pellet is still on ashy side but now burn well.
I am lucky that with my Italian pellet stove I can alter pellet feed rates and combustion blower by 3% at a time. Most pellet stove's especially older units, give a person a 1-5 setting which could be to little or to much of a rate.
I would be very cautious if your stove doesn't like ashy pellets and has sub-standard combustion blower rate.
Updated rating is 3 stars!
Been using them in a cheapie Englander in my shop,
and they are working fine...
24 hours on a bag... maybe a little more ashy than used to,
but no problems..
For around the same money as BBS stuff (around here).... way better...
Dan
Reactions: Harmanizer
Pete, New Englanders may work well i your shop stove but when you compare heat output and ash content a good softie blows them away. It's worth the extra $$'s to buy a good pellet when heating a living area. New Englandersm Stove Chow and Currans are the lowest heat and highest ash output out there!
