My second post what a great forum, I have been reviewing posts here for about a month and have decided on 2 different units. I am removing my Preway FP for a more efficient epa rated FP. I am pretty much sold on the Heatnglo Northstar or Heatilator Constitution. my biggest concern is these may be to much heat for my space. The main living/dining room where the FP is located is 20x28 with 8' ceiling's. I have a 1600 sq ft bungalow roughly 40x40, obviously the heat will seep into the kitchen and other bedrooms on the main floor and the front door foyer/ upstairs stairway is located off of the living room (this area we close off in the winter with the french doors I installed to help keep the heat in the living room and only heat the upstairs at night via a separate thermostat / zone, it's the master bedroom). I am on a slab with a nat gas boiler / baseboard water so there are no ducts in the house.
If I were to install an aux air kit the only way I can see to run a duct would be up through the external chase to tap into the upstairs master bed room (if that is even a possibility). My preway is flush mounted into the chase.
With all of that said I mainly want to heat the downstairs and don't want to be roasted out of the house. Some threads say install a smaller unit and run hot, other treads say go big for a longer burn time I am confused. I am in Michigan north of Detroit and it does get cold but my house is pretty tight. Is there a smaller unit that is 75% efficient that will apply for the tax credit (I really want the tax credit and to be more efficient), or should I go with the Northstar or the Constitution and are these to much heat for my home ?
Thanks in advance for any advice, Mark
