Noticed something I never noticed before
jrogers999
125
Billerica Ma
I woke up this morning for work and went to load up the stove. I noticed there was glowing ash oon left and right inside walls of my M55. It looked freaky. Never noticed that before. Is that normal? Stove was burning on 3 all night. It was a toasty 83 in my living room.
It could've just been fresh fly ash stuck on the old ash. I vacuumed it 2 days ago. So glad I finally finished the New England Pellet crap. The spruces put out some serious heat. The ash is nice and gray and not that black crap.
I'm definitely a softwood fan for heat. I did LG Granuals last year and loved those too.
Reactions: Eatonpcat
I get fly ash sticking to the sides occasionally and it glows for a few seconds until it burns out. Not a ton of glowing embers...just a few here and there. Hope that helps subside any concern...or maybe it will raise some on my side.
"Did you ever notice notice that the fireplace and chimney are the only thing left in a burnt out building? Kinda narrows down the suspects now doesn't it."
Reactions: Wildo
My granddaughter saw that a couple of days ago. Said it looked cool. I went and looked and saw a glowing line moving its way up the side of the chamber. It was fly ash. No harm done and after a run on #5, it was all gone anyways. (It did look cool!)
Probably happens all the time. Just never noticed it. It was morning still dark and really dragging a@$ to go to work.
Reactions: Wildo
That's more than likely a dirty burn. Its incomplete combustion.
Have Never had any fly ash catch fire? If there is something left to burn? It will.
In all my time burning pellets and reading here. I have Never heard of it?
(Sounds like a common thing for the M-55/ 3 users above)?
Possible explination...
If your combustion blower is over-blowing (or air damper is set open too much) you could possibly be blowing little "pellet pieces"out of the burn pot before they are totally burned through. I dont mean to suggest that you have a tornado in there whipping pellets around, but as the pellets burn up and get smaller, the residuals may be small enough and the air may be big enough to sent the pieces out. If there is fly ash on the inside walls, the pieces have a place to stick. Just a possibility, not conclusive.
That's pretty much the long and short of it. It happens when new pellets drop into the pot and cause a disturbance. It's not as if it's sitting there burning on the side for 5 minutes. A few seconds at most. Happens to me with me damper set using the mag. and a totally clean stove. If it's avoidable or wrong I'm not sure what else I would really do. It doesn't bother me and it runs great. Depending on the pellet I get the nice fluffy ash like I'm supposed to with little to no clinkers so everything pretty much checks out. Never thought about it until this thread. Oh well. Cleaning day.
It surely isn't going to hurt anything so If it doesn't bother you then leave it as is. As for me?....Hey, I can't see it from my house.:cool:
That glowing line (sparkling) going up the side and frequently branching is a very small amount of creosote and other volatiles lighting up.
It will occur more on low burn than higher heat levels and more so after the stove has started to ash up, or when the stove starts up after cycling off when on a t-stat.
After all you are burning wood.
Reactions: DexterDay
I have seen it too. It's mesmerizing to watch.
I have seen it on my fire grate but never on the side walls. Mostly when on low and when it changes to high or goes to shutdown(fans ramp up). Pretty cool to watch it spread.
I notice its black in the area before it happens, Might be a rich burn that causes it?
