What is a good OAK to install on a XXV pellet stove. Brand and or part# would be appreciated. Thanks.
So it has worked for 9 years without complaint and now you want to know if it is sufficient ?Did I screw up by trusting the Harman dealer I bought the stove from or is this method for an OAK setup sufficient?
sorry but I don't see where i said it worked fine for 9 years, maybe I wrote that part in invisible ink
I've owned it for nine years is what i said. It's been screwing up for probably 8 years at least with different countless problems
I figure the lemon needs all the help it can get so I was just wondering if my OAK setup was detrimental to it functioning properly. Seems if yours fits tight you just may have the correct size, I mentioned mine is way smaller diamater than it should be to match up, nothing like yours is
and....NO, I don't see where I said it ain't broke either, it's had numerous problems it's whole life
Your crystal ball seems to be malfunctioning 😏 time to take it to the shop to have it reprogrammed![]()
Thank you Sir! That's what I was wondering was if the smaller pipe interfered with the flapper what negative effect would that have on the stove's function? This may be the cause of my problems right there.The only difference between a larger flex pipe and a smaller one is that with the larger you will draw most of your air from outside and with the smaller will allow the stove to draw inside are too.
A potential problem with the smaller flex pipe is you may push it in too far to the stove's intake and inhibit the flapper.
Thanks for the response. I can't seem to find that size of flex pipe but I have not checked the stove store yet. They seem to sell everything at premium price and was hoping to save a few pennies. I could just go with 3" I guess.The P43 uses a 2 3/8” id flex pipe normally, going smaller may put more load on the combustion fan, going to a 3” would be better…think of it this way…soda through a small straw verses through a larger diameter straw
