Hi all,
Ok, this is gonna sound really obvious to some of you...
But I've been really learning the stove this year and found I can get the BEST burns by shoving the stove FULL and then shutting the air all the way.
If I fill it 2/3rd, shutting the air all the way will kill it under the same circumstances.
But if it's, say, 450 stove top and I shove it full, I can shut the air down and within 10 minutes it's roaring secondaries, spiking up to 650-700 with the fan on high the whole time, and burning for hours.
So I recently "figured out" the science behind this -
With the stove box full, there's alot less AIR in the box. So I can shut the air input down, and it doesn't need nearly as much oxygen in order to burn really efficiently. Whereas, if I leave another .5 cubic feet of space free in there - it requires more air input (oxygen) in order to burn.
Meanwhile, I'm getting less overall heat output & more wood consumption when I'm only loading in 1/2 to 2/3rds full.
And it's all a matter of airspace available in the stove - less airspace = less air input needed to burn efficiently = greater heat output and slower burns due to less overall air flow.
There's my equation for the night
Joe
Joe
