old regency H2100M, 1991 help
matlocc
29
michigan
I can't find much information about this unit and Regency is horrible to communicate with. I need to know how much space should be between the baffle board and the metal lip that drops down from the top of the fire box. I am restoring this unit and don't want to block the airflow too much.
If you get the correct replacement baffles (033-955 Baffle (2/set) I2100), you shouldn't need to know that.
Push them all the way to the rear & as far to either side as you can. The underside of both baffles should
be in contact with the air tubes.
The entire manual is here:
(broken link removed to http://www.regency-fire.com/Customer-Care/Manuals/Discontinued-Manuals.aspx)
Scroll down thru the wood & pellet burning products til you see your model number.
I appreciate the baffle number but my stove only has one tube, in the front. no openings for any others. The baffles I ordered seem to only leave about a 1/4 to 1/2 inch opening. The manual on line ends on page 16, page 17 shows the parts of course!
My Bad. I mis-read as I2100 not H2100. I can read all the pages fine,
right down to page 20. Here's MOST of page 17... with the rest of it below...
[Hearth.com] old regency H2100M, 1991 help [Hearth.com] old regency H2100M, 1991 help
