Old Stove new Set up
freeeparker
1
NWMN
I recently was given an old rusty 1979 Fisher Goldilocks, but after days of rehab it almost looks brand new, but now have questions about setup.
I plan on using it to take the chill off in a house that heats with fuel oil and at one time had a wood stove in the dining room. There is access to the brick chimney, that appears to have a liner (clay), in the dining room where there is a round tin covering up a hole that is just under 6" in diameter to the chimney.
I planned on using double wall stove pipe, but with 6" clearance how to I get it to the hole in the chimney? Could I use two 45deg elbows? I read on another post about having to much draft because of two big of chimney and once I tap into chimney it is much bigger then 6". Is this a huge problem?
The Goldilocks was made to take in outside air, but I was just going to lift it up an 1" or so instead of cutting my dining room floor (at least for now). I did get the air intake on the front of the stove working smoothly and was wondering if I should still put a damper in the stovepipe and if so how high above to stove should the damper go?
Holy smokes! Can anyone say thank goodness for free advice.
Do not use an old unknown chimney until you at least had it scoped to check for its interior condition. You get more "free" heat from running stove pipe up instead of sending that heat up a chimney too. Something to consider. If the existing chimney is used for any other heat source then you should not be loading it up with another wood burning stove.
