Olso owners
knotdodger
43
Coleman Michigan
Had a couple questions,
What size area do you heat with it??
What stove top temp can you get it too if needed??
I am still torn between stoves here is all.
I can't make up my mind between the Olso and Hearthstone Shelburne.
Not many people have Shelburne's. Alot have the Olso.
Must be something there!? The Jotul dealer by me has an Oslo
Matte black for 2150.00. It costs so much more for blue/black
because they have to order it 2750.00 wow! The Shelburne is 2000.00
In any finish. About the same size firebox 2.0 cf. The oslo wiegh's
about 45lbs more. Ok third question:::
Michigan people, Do you have a jotul dealer near you with better pricing????
Thank's , I look forward to reading any replie's.
I heat right around 1600 sq. ft. with my 500. It does it with ease, in fact we often have the windows open. I can get the stove top in the 550-600 range pretty easily, never tried to get it any hotter. I can't say why this stove would be better than a Shelburne but I love my Oslo. I paid $2300 for mine in Blue/black about 14 months ago. We wanted white but this one was in stock. It is a nearly indestructible finish as I have a two and a three year old that love to throw things.
I forgot to mention that my house is only 1400 sf. Built in 1964 , could use some insulation.
It get's below zero a few days a year. In the teen's and single digits quite often in the winter.
I cut my own firewood. 75% of it is poplar. Hey, it's free except for time and feul mix.hehe
Both stoves are good models. The Shelburne that I looked at was really nicely made. It has the same blue-black enamel process that the Oslo has. If it were me, I'd prolly get the Shelburne, be happy and pocket the savings.
I reckon the oslo will heat your place just fine. Depends how cold it is here in PA, but mine will heat my whole house down to about 30 degrees. (2200 sq. ft.) When it gets in the 20's, teens, and single digits I gotta run the heat pump, but that's because of the layout of our home. We have 1800+ sq. ft. on one floor, and the master bedroom/bathroom is kind of separate from the main area of the home, so we have a heat pump for back there. I guarantee my oslo would heat 1800 sq. feet if it's insulated decent right down to 0 degrees. (a lot also has to do with wind, under windy conditions, and temps. in the 20's/teens/below zero, I gotta keep the bad boy fired up to maintain).
Now, you should take into consideration burn times/loading intervals too. I had a Vermont Castings Defiant, top load, catalytic, and sometimes I wish I had that puppy again. It would take a 2 foot split, had a 3 cu. ft. firebox, and in catalytic mode would easy burn for 10+ hours.
Woodburner and Oslo owner since Nov 2008. Heating 1458 sq ft, milled log house, very tight, double glazed windows, open concept design, all cathedral ceilings. Using 2 yr seasoned ash and 9 month semi-seasoned red oak. 1st floor maintains 74 and 2nd floor 78...regardless of outside temps (even at -10f). Oil furnace rarely fires...and only if temps fall below 71. Generally get a 4 hr burn time with a packed load (4 hrs of HEATING, not just burn). Generally run between 300 and 500 stove top temps (left rear corner). Never been able to get above 550 without risking 650+ on the flue temp.
  • [Hearth.com] Olso owners
I am quite satisfied with my Oslo selection. I shopped and purchased early last summer, so this has been the stove's first winter. We have an old farm house with an attic and basement and about 1,400 sq. ft. to warm up. The floor plan is not ideal for airflow, but even so we did really well keeping the house comfy and the oil furnace off. I have double oil tanks outside which were full in Sept. I have used 1/4 of one tank of oil thus far!! Most of that is used up on days not quite hot enough to start a fire but needing a bit of heat. In the dead cold of the coldest days, this stove hummed. Maybe it is just me, but I can hear a faint, soft sound like a hum when the stove is burning its best. Nobody else around here hears this, but we're getting older and I know I have the best hearing of our bunch.
There was a learning curve for me with this stove, however. It is pick, pick, picky about any sort of damp or not well seasoned wood unless you allow a nice, thick coal bed. Starting a fire in a cold stove with any dampness and keeping it going just about can't be done, I think. With this stove, I didn't need to start a 'new' fire for over a month at a time. I shovel coal and ash every couple/three days right out of my stove as it is beginning to burn down, but I leave plenty of coal to keep going.
I bought my Oslo because of the sweet deal I got on it. I looked at both the Shelburne and Bennington. Plain and simple, I had a budget and was able to get my Oslo for the price other dealers were getting for the Castine back in 2004.
The Shelburne is a really nice stove but has no side loading door which is what I wanted. Either stove will do, a flat blk Oslo or a painted Shelburne with no side door......good luck with your purchase.
Been burning my Oslo since 2004 with no problems at all
I heat an 1,800 sq ft house that was built in 1750
I can get the Oslo up to 600-650 no problem at all
I burn 24/7 and average 3.5 cords a year here in CT
Did I mention I love the side loading door?
WB
I had the same dilemna as you . . . the Shelburne or the Oslo. In the end I went with the Oslo.
My specs: Heating approximately 1,800 square feet (Cape) with moderate insulation (three 2 x 4 walls with fiberglass insulation and one 2 x 6 wall with fiberglass insulation) using a mix of mostly hardwood.
The stove: I typically run the stove between 500-600 degrees F. I have on occasion (twice) accidentally let the stove go up to 700 degrees F.
My opinion: I would buy this same stove in a heartbeat . . . or maybe one in a blue black finish for a little more bling than my traditional matte black finish (although the matte black means I can easily spruce it up this Summer with some stove polish). The Oslo is a heater -- plain and simple. I think it looks good, but more importantly to me it produces heat which is why I bought a woodstove. Originally I bought this stove thinking I would use it to supplement my oil boiler when oil prices were sky high . . . figured it would be good for weekend and evening fires. Foolish me . . . I have pretty much used this around the clock . . . and the fact that my oil tank has dropped from 3/4 of a tank to a point about halfway between 1/2 and 3/4 mark on the tank level indicator shows it.
As I said, I use this now as my primary heat source . . . although to be fair I have a small electric space heater in my mudroom/guest bathroom/utility room . . . since my oil boiler rarely comes on (unless it is really, really cold, when I'm lazy and haven't refilled the firebox overnight in middle of January or in the shoulder seasons) I use the space heater to keep that room (and the water pipes) warm . . . kind of odd if you think about it . . . I'm basically running a heater to keep another heater warm (well that and guests seem to hate sitting on cold toilet seats.) :)
I have never been cold with my oil boiler (thanks to hot water baseboard), but I will say the Oslo really pumps out the heat. It is truly a workhorse when it comes to producing heat for a wide range of temps -- from using it to warm the place up in the mornings or evenings in the shoulder seasons or to really keeping it warm in the house when it's 20 below zero and the winds are howling (although on those days I sometimes wish I had the larger Firelight as you can see the Oslo is really cranking.) As Peter said it easily puts out 3-4 hours of meaningful heat in the dead of winter and during this time of year you can get the fire going in the evenings and let it die overnight . . . and the house stays warm until the morning at which point you can easily get it going again with the coals in the firebox.
Originally I was thinking that I would have to shut off my upstairs bedrooms and bathroom . . . but I have discoverd that the Oslo puts out more than enough heat to warm up the whole house with the exception of the aforementioned mudroom space. I do occasionally use a fan to help move the heat through the home . . . typically in the dead of winter.
The only negative I have witht the stove is the ash build up in the front of the stove which dumps out everytime I open the front for cleaning . . . well that and the realization that and the manufacturer's definition of burn time is quite different than my definition. On the pro- side I love the simplicity/reliability of the stove (the main reason I went with this brand), side loading door, ash pan, large front viewing window and close clearances.
As I stated earlier I also looked at the Shelburne and the Pacific Energy T6 lines. I liked those stoves as well, but opted for the Oslo since the reviews here were overwhelmingly positive . . . plus when I asked more than one dealer selling multiple brands they all said the same thing -- the Oslo is one of those stoves that is built well with few repair issues typically. Not to start any brand bashing, but one dealer said once he sells an Oslo he typically doesn't hear anything from a customer for several years until it is time to put new gaskets in the stove . . . and that he felt the baffle was less fragile than the one in the Hearthstone line . . . again, not brand bashing, just repeating one dealer's own opinion.
This said . . . if you have truly narrowed your choice to these two stoves . . . based on what I've read here from owners of both brands . . . you should be good with either one.
Peter . . . I was intrigued. Typically if I'm running my stove between 500-600 my flue temp is running between 500 and 800 (sometimes a bit more at the start of the burning cycle and a bit less (400) when it starts coaling). It seems to me that 650 degrees F is a good flue temp . . . but I was under the assumption that most flues can still easily handle routine temps up to 800 degrees F without any issues . . . although I should back up and say these flue temps are with a probe thermometer in double wall pipe.
I bought an Oslo this past year and don't regret it at all. Very good, dependable stove.
Knot,
I've had my stove for two seasons after using a steel box stove for the prevous 26 years and really love it. I heat 2100 sq. ft, 24/7, open concept tri level with cathedral ceilings and skylights on the upper level. I have my furnace set at 66F and it runs in the morning when the outside temp drops below 10F. We load at 10p and at 6a the stovetop is at 200F with plenty of coals to get the fire going again. Normal stovetop running temps for me are between 400F and 500F with great secondary burn and the house is always at least 70F. I would never own a stove without a side door. I looked at the Bennngton when looking for a new stove and decided that Hearth Stone makes great soapstone stoves and Jotul makes great cast stoves. If you can find the extra money, I would get the blue/black as it cleans up nicely and looks good. If you're afraid of the size, you can always make a small fire in a big stove.
Hope this helps
Jim
stop holding back on how much you all love the f500.i might be getting one this week and need to really here how good it is.
John
If it were me I'd go with the Jotul because of the side loading door and stronger baffle system.
I will say i do love my f400.its made well. it is easy to to get going and it can give some heat.i will know tomorrow what i will do.
John
John
I didnt realize you were considering buying one when you asked where i bought mine in my thread earlier. With that being said I did a lot of searching and Prestons had the best price on the Oslo. Also, craigslist is a great tool when/if you sell your F400. I had my Vigilant on only about two days before the thing sold.
I'd love to hear the decision,
Good luck!
mikepinto65 said:
John
Good luck!
The Castine is staying put.The oslo will warm my floors that will warm my feet :-) i think i'm falling in love :red:
I'll let you know.
Thanks John
johnnywarm said:
mikepinto65 said:
John
Good luck!
I'll let you know.
Thanks John
HaHa, i took the insulation out so the stove could warm the floor boards too, it worked very well when the Vigilant was in....and it felt amazing!
I'm a Oslo owner!!!!!!!!!!!!!!!!! Its on the truck as i type.
John :coolsmile:
John :coolsmile:
Congrats! did you decided to go with the matte black or an enamel?
Be sure to crack a window and use a fan when you break her in (im sure u experienced the stink with the 400)
Would love to see pictures when you get it in!!
mikepinto65 said:
John :coolsmile:
Pics Soon!!!
John :coolsmile:
Welcome to the fraternity. ;) :)
Congrats!!! I can't wait to burn mine for the first time!
Congrats. If you bought an enamel stove, it won't smoke at all when you light it for the first time.
Jim
Ummm, it will still off gas a bit. There are other cements and oils from manufacturing that will smoke when lit. If yours didnt, consider yourself lucky! Grats on your new purchase! the olso rocks.
