Thank you VERY much to everyone with the fantastic information! What I am taking away:
-should definitely go with something the size of an Englander 13, or maybe even a touch larger. Thanx, that might have been a costly error to go small
-should take a good hard look at soapstone.
-if I have good wood, I can burn hot and fast or long/slow. . . . Yes to all of the above . . . and especially about taking a good hard look at the soapstone stoves . . . they might be perfect for you.
For my neighbor in Bangor/Unity, the cabin is in Washington, Maine. Yeah, no pianos on the 2nd floor. And yeah, I almost wrote "popple," but no one out west knows what that means... Actually Dennis in Michigan (well I don't know if I would call that out west . . . just west of us . . . knows popple quite well . . . and it looks like we're practically neighbors . . . couple college friends lived in your area at one time . . . EB White had family living in Appleton and David Karas had a family with a Christmas tree farm . . . of course I haven't heard from either of them in years . . .
Thanx also for the info on creosote and hot/fast versus slow fires. I've never measured moisture content, but would consider wood that has dried in a dry shed to be well-seasoned. Is that the case? Well it depends . . . I don't use a moisture meter, but generally if I've bucked up, split and stacked my wood for at least a year prior to putting it into the woodshed I'm good to go . . . although because I have a large enough woodshed and it has a board and batten side (minus the batten) the wood continues to season albeit at a slower pace for another year or so. If I just bucked up and split my wood and stuck it into a woodshed I don't think I would have very good luck with a modern EPA stove. And also in the context of creosote (a question for anyone), I've heard of "proper operation of the stove" as another key to avoiding creosote...what constitutes proper operation, what are some key do's and don'ts in regard to creosote and stove operation? Proper stove operation kind of boils down to two things (once you've got seasoned wood) -- making sure you run the stove at the optimal temps (thermometers help on the stack and on the stove) and learning how to run the air control so you can achieve a good, sustained secondary burn (for secondary burn stoves.) Thanx again to all!
Davis
