lbcynya said:
			Ditto.  Shoulder seasons are tough for evaluating pellet useage.  I don't have any science to back this up, but I would imagine our stoves are designed to be most efficient at higher burn rates.  So, while it might seem that idling along is saving pellets, you don't really get the heat out of the pellet and into the room.  As the stove temp rises, so does its ability to push heat into the room.
Once it's good and cold and you can let it crank and you'll get a better idea.  If you are using a high BTU pellet and fell the stove is in good working order, then the heat your house consumes is what it its and you'll need the appropriate amount of BTU's to replace the heat that's lost.  If you lose 25,000 BTU per hour, then you'd need to burn about 4-5 pounds per hour to keep up.
i have heard the same thing about the stove being more efficient on the high setting.
and that the official reported efficiency number for the stove comes from being run on high.
what i've been doing is running on high when i start up in the evening. and getting the far end of the house to the temp we've decided is best. then running on medium w/ the thermostat set to reduce the noise for sleeping time.
the high setting full time (at this point in the season) just makes our little living room too hot over the long run.
on medium with the t-stat set to our desired current level, the living room cycles between 75 and 80 or 81 degrees per burn.
the temp in the living room fluctuates. but the other rooms stay pretty much steady.
we spend most of our time in the other rooms anyway. tv room and computer room and back bedroom.
i still have a lot of experimenting to do with my first season with the stove. and as we get to the really cold 24/7 season.
dexter runs on low afaik. but he has done a whole lot of work reducing the heat his house loses.
i'm *guessing* that is what makes running on low worthwhile.
just maintaining the "soak temp" and not asking the stove to push the heat that far.
we also just got our vornado humidifier today. it is also an air circulator .
the output goes straight up and the inlets are on the bottom to create convection.
it will be nice to harvest the heat from the ceiling of the living room and spread it around better.
properly humid air is also supposed to feel warmer.
