My stove sits just outside my fireplace and the SS liner rear vents about 18" then straight up the masonry chimney. So, after sweeping the flue do I have to disconnect the stove, move it, and then clean out the creosote I've dislodged? (as u can tell, this will be my first time at this). The thought of moving that heavy stove makes me think there is an easier way. I've searched some old threads but don't see what I need - even though creosote cleaning is a hot topic. :cheese:
. Just lift up slightly on one side and slide it forward about an inch or two. Then go to the other side and do the same. As soon as you can reach the flue collar, unscrew it. If it's on a rough surface, put some sheetmetal under the front feet to help it slide better. Seriously, the T6 slides on the hearth tiles pretty easily. I can do it myself and I am no hulk.
