One more question about liner install
EmmyQT
30
Rhode Island
We measured the present (I think clay) liner which measures 6.5 x 10.5. We are definitely going to insulate around so of course have to add another inch to whichever liner gets installed. I've been looking into rectangular liners and found a few measuring 4 x8.5; 5x7.5 or 4.5 x 8. The 4.5 x 8 one seems to be the closest to the 6" required liner. Is that best way to go with the given measurements of present liner? I also was looking at oval liners. Are those better than rectangular? Both the rectangular and oval ones are the FireFlex 316Ti .006. We were also looking at 4" x 8" 316L but because it's going to be two people installing the liner and read that you might need a lift, etc for the 316L we shied away from that. We're definitely open to any comments or suggestions. Thanks so much for all the help and the much needed good advice. This forum is awesome. : )
How in the world are you going to go from rectangular to round to go into the flue collar of the stove?
There's an pipe adapter that goes from rectangular to round.
Always willing to learn. I have seen a boatload of adapters for a rectangular flue outlet in an insert to a round liner but I have never seen the other way around. But I have led a sheltered life.
Reactions: EmmyQT
OK. I just found one. Never mind.
Reactions: EmmyQT
We looked into the pricing of these and there are HUGE differences. The best price is for the 4" x 8" oval chimney liner kit, double ply smooth, 316L. Is it true that these are very hard to work with? And secondly would it work just as good as the 6" round?
Also, could I use my existing top plate and rain cap?
Look into DuraLiner oval pipe. It is preinsulated and made for this type of installation. Pipe OD 4.75" x 7.75". They have a full system including rigid and flex piping, tees, etc..It will cost a bit more but it is a high quality product with a thicker inner liner and the insulation is built into the pipe.
(broken link removed to http://www.duravent.com/Product.aspx?hProduct=6)
http://www.dynamitebuys.com/store/cart.php?m=product_detail&p=1274
http://www.dynamitebuys.com/store/cart.php?m=product_list&c=66
Reactions: EmmyQT
Awesome, I will check this out. Thanks!
Don't think I have seen how tall is this chimney?
Reactions: EmmyQT
We need to get up on roof to measure better which is on the list of one of the things to do next, but it's roughly 15 to 20 foot.
I understand round is better than oval as far as airflow or draft. But it seems consensus is also insulating is better than non-insulating. So is it better to go with 6 inch round with only insulating top and bottom with Roxul or is it better to go with 4.5 x 8 oval with an insulating kit? The current liner is 6.5 x 10.5 ID so choices are limited short of busting out current liner which we really do not want to consider. This seems to be one of the hardest but most important decisions and before we commit to which way to go, we'd like to hear from people who have done it either way and if they're happy with how it drafts. This is an exterior chimney, and I can tell you from how the fireplace drafted sometimes (and the amount of creosote in the chimney) that the draft could have been better.
I think that insulation is very important for safety and performance so I would recommend a fully insulated oval I know some don't agree with this but it is what I have found and been taught. I would not use a rectangle they are way to expensive and don't really draft that well.
Reactions: EmmyQT
