It all started with a new kitchen floor...
Now She wants a pass-through/breakfast bar in the wall between the kitchen and the dining room. This is a load-bearing wall, so I'll need a support beam across the top of the opening. Currently, there's a door at one end and I envision the bar cut into the wall, from the door opening, about 6 feet. The total span should run no more than 8-1/2 feet, depending on how long we decide to make the breakfast bar. Above this is the boys bedroom and part of the hallway (no support walls or major weight).
I'm thinking of making the beam out of two 2 X somethings, sandwiching a piece of 3/4" plywood. The question is 2 X whats? Do I need 2x8's, 2X10's or 2X12's. I want it plenty strong enough, but I also might want to put in some recessed light fixtures in the header below the beam.
Thoughts, suggestions or experience??
Thanks
Thanks
