Hi,
I have an Arrow Fireplace insert, probably from the 70's or 80's, as my house was built in 1976. It says model 203408 on it. I pulled the insert out last year, and noticed it is not connected to the chimney at all - it was just put into the fireplace opening and that's it.
I really like the insert - it is easy to control and heats the house very well. It's very efficient.
However, I've read that no connection to the chimney can be dangerous and hard to clean.
So I've called around, and this is what I've found:
What is your opinion? Would I be better off / safer to just buy a new insert? Are newer inserts really better? A lot of times things built in the old days are higher quality than the new ones.
Or should I try to clean the chimney and install a liner myself? I have quite a bit of experience, and my dad would help me - he built his own house, chimney, electrical, plumbing, etc all himself.
Thanks for any advice or opinions.
- Inserts prior to the '90s are not up to code, so legally contractors or chimney sweeps cannot install a liner for me
- Since it's not up to code, chimney sweeps won't clean the chimney either, for liability reasons
- I need the chimney cleaned before I could do a DIY liner install
- If I bought a new insert from a local shop, the cheapest one is $1899 + 495 for a 6" liner kit + $800 labor to install
- I can buy the 8" liner for $700 from the local shop and do it myself, but I would still need the chimney cleaned first
