I'm making my own hearth for my wood stove. The R-Value has been taken care of with a sheet of Micore. But I'm guessing for strength/durability I should use a sheet of plywood and a sheet of cement board along with the tile/grout.
I figure the correct order would be plywood, micore, cement board, grout, tile. Does that sound right?
I was told I can use any tile and grout I want so we found one that works at Lowes. Only problem is that I'm trying to get away without using a tile/wet saw and the tiles are 12"x12" and the micore (and other sheets) are 4'x8'. So I'm thinking I can have the tile extend a little over the edges and then maybe put the wood trim under and around for support.
I'm curious what wood yall use for the trim?
I thought it was baseboard or maybe chair rail but it doesn't look like any that Lowes/HD offers from the pics I've seen here.
Please share your thoughts. Thanks!
-Emt1581
-Emt1581
