Boy that thing is small
I went to the True value by my house, simply amazing how much fireplace stuff they have.
Saw the little F-100 in person for the first time, looks great! Still trying to decide if I should go the blue/black porcelain enamel or just the matte black. The salesman (very knowledgeable) says that since I am doing a corner install that I should go with their black seamless single wall pipe on the inside and the Sure-Temp Stainless outside. He says I should have enough clearance to my knotty pine to use the single wall. The seamless is pretty nice stuff but I don't know about the quality because I don't know much about this stuff. I can tell you one thing, I DON'T want to have to replace this stuff-EVER! I just want to do it and have it last until I die. Is there something else I should use on the inside or outside for that matter if this is the case? I am going to order the long leg kit to raise it up a bit. They also offer a fresh air kit I forgot to ask about, what is it and do I want it? I guess that's about it, getting excited to get it and put it in! Thank you all very much.
Daryl
I went to the True value by my house, simply amazing how much fireplace stuff they have.Saw the little F-100 in person for the first time, looks great! Still trying to decide if I should go the blue/black porcelain enamel or just the matte black. The salesman (very knowledgeable) says that since I am doing a corner install that I should go with their black seamless single wall pipe on the inside and the Sure-Temp Stainless outside. He says I should have enough clearance to my knotty pine to use the single wall. The seamless is pretty nice stuff but I don't know about the quality because I don't know much about this stuff. I can tell you one thing, I DON'T want to have to replace this stuff-EVER! I just want to do it and have it last until I die. Is there something else I should use on the inside or outside for that matter if this is the case? I am going to order the long leg kit to raise it up a bit. They also offer a fresh air kit I forgot to ask about, what is it and do I want it? I guess that's about it, getting excited to get it and put it in! Thank you all very much.
Daryl
Before I moved mine when it was cranking it would heat my basement office which is a thousand sq. ft.
