I'm currently in the process of trying to figure out which wood cookstove will work best for my home. I'm looking for a cookstove as my home has limited power options and having an electric or gas stove is not possible. My home is 2 stories tall with the main level being storage and the actual living space on the 2nd floor. So essentially like a single room cabin with a basement, but the basement is actually on the main floor. The room the stove will be in is one large open space and about 330 sq ft with vaulted ceiling that go from 9 to 14 feet on the 2nd floor. I'm located in Mid/Northern Michigan.
I will use this stove in winter part time for supplemental heat to assist my electric heater, but I also would love to have the cooking utility of the oven and cooktop since I don't have those right now. I've got an ample supply of wood and I process it myself, so a woodstove matches my fuel supply I have on the property. One of the main reasons I want the stove is backup heating supply since the power goes out frequently in winter and I lose my electric heat.
My plan is to install the wood cookstove centrally in the room and add a fresh air intake kit to pull air from outside since I've already had issues with having too tight of a room where I get CO2 buildup issues unless I have a window open, so I know a stove would not have adequate air supply from within the room alone. I can run a straight double wall pipe up vertically through my roof near the peak and I'll have somewhere around 16 feet of chimney so I think I'll have decent draft since most of that pipe will be indoors and it will be a straight shot up with no bends.
In terms of stove options I've somewhat narrowed it down to 2 options (but am open to other options)
Dwarf 5k Cookstove (https://www.tinywoodstove.com/product/dwarf-cookstove/)
Pros
BTU matches space size fairly well
Small footprint - easier locating and shielding
Lightweight (relatively) which makes my floor reinforcement simpler
All in one kit option from manufacturer simplifies building piping
Cons
Smaller firebox will require me to cut wood special to fit
Smaller firebox will limit burn times and require frequent reloading
Smaller oven limits cooking in oven
Drolet Bistro (https://www.drolet.ca/us/en/cookstoves/db04815/)
Pros
Larger firebox will allow full size wood
Larger firebox will allow longer burn times with less loading
Cons
On the large size BTU wise for my space, might be hard to manage output
Heavier - will require more floor reinforcement
Larger footprint - will require more spacing and shielding work
I had also looked at a Vermont Bun Burner but I think that stove is too large and it's also out of my price range. I'm open to any other wood cookstove ideas anyone has that might fit this space and requirements. The Drolet is a bit more expensive than the Dwarf 5K, but I've been leaning toward the Drolet just because it seems like it would be easier to maintain fires with the larger firebox, even if I do smaller loads of wood and smaller fires to manage the heat output. But I'm interested in any feedback or suggestions anyone might have. Thanks
Pros
Cons
Pros
Cons
