I'm a newbie trying to decide whether to get a smaller insert (Regency Ci1150) or the larger one (Green Mountain 70) for my space. The Regency will fit better in my existing fireplace while the Green Mountain will protrude ~2" (confirming with installer it isn't more).
All else equal, I would prefer the larger stove for the larger fire box and ability to burn longer. This won't be my primary source of heat, but hopefully will heat enough of my first floor to ease the burden on my boiler. I don't think I'll be able to get good seasoned fire wood this late in the fall so might just buy some of eco bricks to start.
Couple of questions for the experienced folks here:
1) Will I have to get it very hot to burn efficiently / draft well and end up baking out my family room. Even with fans, I'm concerned it will get too warm and running smaller fires won't make sense. I posted the dimensions of the first floor below.
2) Will the Green Mountain sticking out 2" be a real eyesore? It looks like it was designed to sit flush against the fireplace. I'm not totally concerned with the look, I think it probably will heat the room better with more exposed surface area, but don't want it to look silly. I think with it sticking out I might need to get a heat resistant mat as my existing hearth might be under 16" with the protrusion.
3) Has anyone here used eco bricks and what do you think?
Thank you everyone in advance.
