Lopi, PE or Regency wood insert and what size?
A custom surround can look really sharp.
If this is an exterior wall fireplace then definitely plan on a block-off plate sealing the damper area and if there is room, mineral or ceramic insulation on the back wall of the fireplace (but none on top of the insert). I would do this regardless of a surround or not. It will definitely improve the heat output into the room.
Which insert do you have? I was looking at the lopi large flush mount. I just couldnt wrap my head around it being able to push out the same heat as a unit that sits on the hearth.
Hi, it's in my signature: Jotul C450 Kennebec insert. I can't say it's the "same heat" as a stove standing outside the fireplace, but especially with the back doors open on my double-sided fireplace, we can heat the whole downstairs to "normal" temps and the upstairs enough for sleeping (we like it cool for that).
-dan
Hmmm... I never considered a slightly inset custom surround to preserve the arch. If I went with no surround, I'd definitely want a damper back plate, right? Just added more options to consider. 👍
With that nice stone arch, maybe consider doing a custom surround (or none at all). A custom surround could be slightly inset into the arch instead of the stock one covering it up.
I had a chance to take a long look at the Lopi Large Flush NextGen Hybrid Arch (Boston Faceplate) and the (Regency) Hampton HI2450 at a NH stove shop today. Both with a 25' hybrid liner wrapped with insulation. The hi2400 would need a small 12x48" steel hearth board extension (as it protrudes) to protect the wood floor. The Lopi would not as I have 20" from stone face to floor. They mentioned they could fabricate a custom backplate (outside the arch, not inside) for the hi2450 to follow the arch. Both have a good sized door fire viewing area. The rough difference is ~$1,300 with the Lopi the slightly more expensive choice.
I'm leaning Lopi unless there's a good reason to go Hampton (a slight protrusion would help heating). Is the Lopi cat easy to use vs. the Hampton non-cat approach.
So many details and considerations... ARRGH!
In general terms, a flush insert needs the blower much more to convect heat into the room than an insert that projects out onto the hearth. There is more exposed, radiant surface area in the latter case. This can be important if long power outages happen in the winter.
The non-cat is a simpler stove with less parts, and less maintenance. A cat/hybrid has a bypass for starting and the cat which needs cleaning and replacement about every 10,000 to 12,000 hrs. The Hampton has a deeper 13" firebox than the 9" deep Lopi firebox. That would be easier to load N/S, albeit with short splits.
Reactions: My3sons_NH
Thanks @begreen and my apologies to @LZfamily for semi-hijacking their thread. 👼 Good points for the hi2450 with more radiant heat area, less long term maintenance and an overall more simple operation.
