Regency Hampton HI 2450 burning through wood FAST!
LZfamily
38
Illinois
Hi Everyone. I was on the fence for a while about Lopi large Flush mount insert and regency hampton hi 2450 insert. I liked the look of regency, we wanted one that went out onto the hearth. I knew Lopi would work well, since we owned a Lopi stove in our old house and loved it, but didnt like the look being flush and we didnt have the space for a stove. It was a hard call since I know Lopi burn great, but I really dont like the flush look. We got Hampton hi 2450 installed last Friday, the guy told us to take it though a process of burns to fully warm up than cool down, once that was done we started burring wood more. But this is bleeding through wood SO FAST, is this normal? I try to low burn it but then the glass starts getting dark so I know their is build up starting which we don't want. Any suggestions or tips? Am I doing something wrong? Is there such a thing as too dry of wood, we have 9-12% tested on a moisture reader. I am starting to have buyers regret that while I did not like the flush mount I know Lopi is a great insert.
Someone help so I dont regret this!
How tall is your chimney? Explain your burn procedure including how it is loaded and air settings
How did you test your wood to get that 9-12%? Did you resplit a piece then test the inside of the freshly split piece?
I used a moisture reader with the prongs, no i did not re-split to test it, but it was sitting out split for years, when I knock them together they sound hallow and they are the darker color. So I feel pretty good that they are really dry pieces of wood.
If the wood was split years ago I agree it is probably dry, but the reading you took is useless. The wood needs to be resplit right before you test it for an accurate reading.
Reactions: ctreitzell
2 story house, exterior chimney, I think 35 feet if I had to guess. I start it with some dry wood, and 1-2 pieces of fat wood. let the door stay open and air setting open till flames are going for a while. Then close the door and keep air fully open, as the wood burns down I add more, I keep the airflow fully open until the fan kicks in which is set on automatic. As the coal bed builds up I will try to spread it out before I add more wood. Sometime I load NS other EW just depends on the size of the wood.
I have one of those magnet circle thermometers that I put on the top of the insert since it sticks out a bit and it reads 200-400 deg F.
Thanks for any help.
So you re-split all your wood before you burn it to test to see if it's dry? That seems like way too much work!
That's likely the issue. The draft is too strong. Dry wood will exacerbate the situation. The insert needs to be choked down and the liner needs a damper.
There is an old thread on a Regency that was set up similarly. It started cracking due to the lack of ability to control the fire. He had to restrict the air intake and add a flue damper on the replacement insert to finally get good control over the fire.
No, just a couple pieces, wood from the same batch will be of similar dryness. Just letting you know that testing wood without first resplitting it doesn't tell you anything. The moisture is on the inside.
Dangit, but a strong draft make sense. But when I choked it down the glass would get the black build up so I knew it wasn't burning hot enough. I think I read the one you are talking about, but it was with a cat version so I figured that was the issue. I dont think a flue damper comes on this unit. The company is coming out next week to try to problem shoot it. Anything else I should suspect or talk to them about? When we did the initial burn with the install guys commented on the great updraft, so maybe that is it. If this is the case do you think this is something that I would be stuck trying to install, because I have no clue about how to instal a flue damper.
The darkened glass may be due to wood that is still damp in its core. Partially seasoned wood can cause problems even with the best setup.
A flue damper needs to be installed by someone that knows what they are doing. There are clever ways to solve the installation. It will probably take figuring out an extension to pass through the surround. I'll see if I can locate the old thread on this topic.
Here's the thread with the overdrafting Regency. This fellow engineered a good solution that gave him good control over the stove. The discussion of the issue in this thread may be helpful.
If its that tall you are over drafting. Why are you running with the air wide open so long? With a chimney that tall is would have it shut completely within 5 mins
Wow this is not the thread I had read, I wish I knew how to set up something to tell if I am overdrating. I have a video of me cutting off the air intake and the flames don't change, so I think it must be overdraft. Do you think the company will be able to install a damper or should I push for trying to get a different insert in general? Sadly I couldn't find anyone local to sell BK or PE. The place the installed the Regency also carries Napoleon Fireplaces or Osburn, not sure if they would be any better. Another local company that I was considering sells Lopi. Thank you so much for all your help!
I guess I didnt know any better. We had a lopi stove at our old house, we would run it open to get things nice and cozy than low burn for night time. I have a video I will try to share of me cutting the air intake with this new insert and i dont see any flame changes.
An insert will have an issue with a 35' flue system. This should have been evident right away to the seller and installer. A good installer should have a magnehelic to test draft. The engineer in the referred thread had the same issue. He put instrumentation on his system to pinpoint the overdraft condition and test his remedy.
It will take an experienced installer to come up with a good, workable solution. Some iinstalls have downsized the liner from 6" to 5.5 or even 5" to reduce draft. As a test, the installer could try temporarily reducing the size at liner cap from 6" to 5". A damper advantage is that it allows you to regulate draft depending on the need. Remember, it will get stronger with colder outside temperatures. There are a few other postings on Hearth.com illustrating the fix using a key damper.
Thanks. I just looked up Lopi large flush has a 33 foot max, height so that rules out me getting that one. Crossing my fingers they can put a damper in, I am very thankful for everyone on here!!
I didn't see where anything about the chimney, other than height was mentioned. If it has a 6" insulated liner, great, but it will probably overdraft without a damper inline. If it's just a big ole honkin brick chimney, it may be cold and loosing draft, especially as the stove is turned down.
Plus it's not been that cold out yet either...so the wood usage may be from leaving the stove turned up too long, and the black window might be from the draft collapsing after the stove is turned down.
I agree that the wood could still be wet inside too...plus we don't know the species...it might be gopher wood! (Load the stove, then gopher more wood right away!)
I dug through the install paperwork and it was a 35 foot by 6 inch pipe, but the chimney could not be 35 feet, since that was the total length of the pipe. I can't remember how much extra pipe they had but here is a picture of them putting it in the chimney and looks like it would take it all.
[Hearth.com] Regency Hampton HI 2450 burning through wood FAST!
Yes, that looks more like 25-27' which could make it easier to tame the draft if it's just slightly too strong instead of majorly.
To eliminate variables, take a couple of thicker splits and resplit the in half. Then take a moisture content reading in the middle of the freshly exposed face of the wood with the prongs parallel to the grain. Ideally this would be done with a split close to room temperature.
My stove is in the basement and my chimney goes up on the table end at the peak. I have 27 ft (and with a long horizontal run and two 90s, my stove runs fine; not too strong and not too lackluster).
Now your stove may breathe a bit easier than mine and may therefore need a flue damper. And you need to dial the stove down sooner.
However, are you sure your door is not leaking?
The dollar bill test is good for that: put a bill between the door and insert, close the door, pull it out. If it has resistance, it's ok.
If not, it leaks. (And if it tears -hence a 1 dollar bill and not a 100 dollar bill...- it's tighter than needed.)
A leaking door (or ash door if present) can result in eating thru wood as well.
Not saying it's not the flue height, but there's more to check imo.
Did the dollar test and i couldn't pull it out, but I also didnt try to the point of tearing it.
okay. If that's the case along the length of the gasket all around the door, then that's clearly not the issue.
Back to flue height - damper then.
Thanks for the idea! I looked up regency warranty and it says if you add a damper it will void the warranty :( . Do you think I should start bracing myself for this just not working safely? Would any brand insert work well with such a large flue height? The sales guy who came out originally suggested gas, which I love burning wood too much to do gas, but I wonder if that is going to be his recommendation to swap it out for a gas one. :(
I am planning on making a fire later tonight so I will try this and report back. I looked up regency warranty and it says if you add a damper it will void the warranty :( . Do you think I should start bracing myself for this just not working safely? Would any brand insert work well with such a large flue height? The sales guy who came out originally suggested gas, which I love burning wood too much to do gas, but I wonder if that is going to be his recommendation to swap it out for a gas one. :(
