Still a rookie, I’m wondering if someone might explain the pros/cons of n/s and e/w loading. (and if I understand it correctly, seems many stoves don’t have the dimensions to allow the user this option anyway?)
I think those two reasons sum up why many folks burn north-south or east-west . . . north/south for quick burns and to keep splits from falling against the glass . . . east-west for longer burns.
Me . . . my firebox is rectangular so I pretty much burn everything east-west except at the start of the season when I'm burning my chunks, punks and uglies since the chunks are small enough to go north-south. When I want a long burn (which is pretty typical at this time of year) I load east-west like I always do and go with larger splits and rounds and load up the firebox . . . in the late Spring for a quick, hot fire to take the chill out of the air I'll load east-west like normal, but go with a partial load and use some of my "lesser" wood -- softwoods, poplar, etc. that I've tossed to the side.
I dont give too much thought as to whether they're straight, gay, bi curious..whatever. I do however find that when it is really cold If I position them using both, say a piece n/s then a few small splits E/W it allows for more air curculation and a hot fire without having a full stove. Then when it burns down there isnt a huge bed of coals and I can repeat the process all day with much temp drop in the stove and no big coal buildup. I do the opposite for a long night burn and stuff as much in as possible. Huge colbed in the morn.
I just recently pulled a storm downed Pin Oak from my woods and bucked into ten inch logs, which I split in anticipation of beginning a layered burn next year. Bottom row will be E/W, next layer will be short N/S. I have about half a cord of really great, fresh cut oak that should season by next year since it's cut short and split into smallish pieces.
