They hardwood's will plug up even faster..maybe
That's the experience I've had with my stove. Less clinkers/carbon with the softwoods with ash being lighter.They hardwood's will plug up even faster..maybe
I haven't burned hardwoods in a long while ...do you burn more PPH with hardwoods also?
Yes, same time each day I "inventory" the bin and have marked each level to help judge the usage. I will also scrutinize the usage for the whole week just to make a proper comparison. I believe the combustion settings are the difference. In order to keep the basic minimum flame going my auger rate is higher than the combustion fan setting. When I back the auger rate down the flame begins to wain and the fire gets cold, which brought on a no fuel error. Was your experience is different?How do you know its burning more, did you time the stove run time from start to stop?????????
do you burn more PPH with hardwoods also? I haven't burned hardwoods in a long while ...
Generally just lurk here, but some subjects I just can't leave alone. FWIW, I have a degree in Wood Science & Technology and also considerable experience in the pelleting process. Lake Girl has the best info thus far on the difference between heat output of softwood vs. hardwood. The resins in softwood can contribute to a higher Btu value for softwoods (amount depends on the actual softwood species). Some of these resins are destroyed in the furnish drying process, and some more in the extrusion process, but some remain in the pellets. These resins offgas terpenes and various other volatile organic compounds which is what gives pine its characteristic smell.
Otherwise, the major differences in hardwood vs. softwood are mostly in the vascular structures that transport water and sap. Most other differences (weight, color, density etc.) may be true in most cases, but there are usually exceptions for individual species on both sides. So, SOME species of softwood pellets may produce more heat than SOME species of hardwood pellet, but it is far from a certainty. The VERY BEST softwood pellet will likely produce more Btu/lb than the best hardwood pellet, but the difference will likely be 5% or less.
How much heat you get from your stove is an equation with far more variables than just the Btu value of your pellets. Moisture content is certainly a factor, but the pelleting process itself removes a fairly consistent amount of water, and generally results in pellets coming to you in a pretty narrow and consistent range of moisture content. (Thus you see the generalization on bags of pellets "Less than 5% moisture"). By the way - know what you are looking at with the claimed Btu value that is printed on bags or available on manufacturers websites. Btu value/lb may be figured in two ways - dry value or actual value. Because some heat is necessary to drive off the remaining (< 5%) moisture in a pellet, the Btu value of the pellet as it comes to you is somewhat less than the Btu value figured based on the pellet being absolutely dry. Since your pellets will never be absolutely dry (0% moisture) the dry value Btu rating is essentially worthless. Because Btu value is a selling point, however, some manufacturers like to trumpet the dry basis number as a selling point - a questionable practice at best. I have seen any number of posts here where folks have been tripped up (deceived, actually) by this practice.
Density is important, to a point, as is pellet geometry. I can densify pellets to the point they are nearly bulletproof - they will be extremely hard, super shiny, and darker colored due to the greater heat produced in the extrusion process Better pellet? Not to many folks - they can be harder to ignite and will burn slower. A given weight of wood will require a given amount of air to combust it properly. Therefore, more air is required for a denser pellet to burn properly and completely. The end result for many is incompletely burned pellets (invariably referred to as "ash") being pushed out of the burn pot and accumulating elsewhere. Without an air adjustment, the flame will look lazy, glass will darken quickly, heat output will be low and the stove will require frequent cleaning. Those in the know can adjust their stove and enjoy the benefits of the denser pellet....others will condemn the pellets as "trash"and "full of bark". Which way would you produce them - as good as they can be, or ?
Pellet geometry, especially length, also affects perceived heat output. Your feed auger, working at a set speed, will deliver significantly differing amounts of longer vs. shorter pellets to your burn pot. How different will depend on your particular stove's auger design - diameter and flighting design being especially important. The greater weight of pellets delivered per revolution will obviously produce more heat (again, if and only if, the proper amount of combustion air is provided).
Learning all you can about how your stove operates will be of considerable more value to you quibbling about Btu value of hardwood vs. softwood pellets!
Found the same thing here when I tried Hardwood pellets, they're sometimes crunchy in the auger.. Had me concerned (well, a bit freaked out) when the pellets broke also.
Thanks for posting that info from purplereign, learned something new today.![]()
I thought that was helpful as well, LakeGirl helped me fill in a few other blanks.
her posts on how to disassemble and clean the Ecotech stoves
From wikipedia:
Pellets are produced by compressing the wood material which has first passed through a hammer mill to provide a uniform dough-like mass.[13] This mass is fed to a press where it is squeezed through a die having holes of the size required (normally 6 mm diameter, sometimes 8 mm or larger). The high pressure of the (broken link removed to http://en.wikipedia.org/w/index.php?title=Wood_pellet_press&action=edit&redlink=1) causes the temperature of the wood to increase greatly, and the ligninplasticizes slightly forming a natural "glue" that holds the pellet together as it cools.[7]
Most auger systems allow a little play in the motor. The auger itself is usually aligned with a bearing plate and bearing. Your manual shows two augers - so it pushes pellets into burn pot while the stove I have drops pellets into the burn pot (single auger).
Augers - Figures F & J
(broken link removed to http://www.osburn-mfg.com/upload/documents/manuels/45723A_05-03-2015.pdf)
, I've had no flame outs and still maintained the temp levels in the house. The density of the pellets seems very consistent, I'm able to snap them with some reasonable effort. There's no banging noise from the 1st feed tube auger.
The machines that take the saw logs trim off the limbs and often times that is what finds its way into other products.Slashings as in tree bark and other by products of the forrest floor?
I'll need to build something similar as it's about 10 feet above the ground. Our lilac's are adjacent to the outlet, but down wind.I had the same issue till the Lilacs grew back in the properties wind break. I stuck a couple pallets in a teepee in front of the vent to break the wind. Not uncommon to get 40 plus winds around here. 3 since last Tuesday.
