I am trying to understand why the single wall stove pipe shot up to 800+ (surface temp measured with IR) for about an hour last night. It was pretty unnerving and I had to just ride it out with the primary on the stove completely closed. After an hour it finally calmed down and quickly dropped to 500.
I was at the beginning of a burn with a full load of brick fuel, which I have done without issue in the past. The stove never seemed out of control. I was dialing back the air incrementally when the spike in pipe temps happened. The catalyst was engaged the entire time.
Setup is this: dutchwest 2462 catalytic, 3.5' horizontal stove pipe connected to a 25' liner.
Any ideas? Could this have been a chimney fire? There was no sound and no smell other than burning paint. I didn't see smoke coming out of the chimney, only steam. I can't believe there would be much build up since I am new to burning. It's been mostly night and weekend fires for a few months. Much of this has been brick fuel. I guess I did burn some 30% wood early in the season.
Also, should I be concerned about damage to the pipe? I certainly could hear the metal contracting as it cooled down.
Thanks
Thanks
. Was the by-pass closed when these temps happened? ![[Hearth.com] out of control stove pipe temps [Hearth.com] out of control stove pipe temps](https://www.hearth.com/talk/data/attachments/91/91167-e5c364a4b11845b988d08837d8fdcb9c.jpg?hash=G8Hf8ZAS-z)
