robins44 said:
Looking at purchasing to heat my 3600 square foot house (1 main floor and basement), and a 30x40 polebarn to come in future, do not currently have but plan to build hopefully summer. I am looking at
http://ridgewoodstove.com/ridgewoodsept_002.htm . They are local (10 mins away) and the price is definately right. Wanted to know if theres anything specific i should look at, ask? Or any concerns that you fellers see. Also should i spring for the larger model seeings how i want to build my pole barn? Also will the larger unit use more wood until i get my pole barn, and if so will it be a signficant difference?
Thanks
Cody
Cody,
Yes, you do get what you pay for so I'm leary of all "cheap" units, but, without seeing one in person it's hard to give an opinion either way. What I will tell you is that I have a Central Boiler 6048 and I heat 3000 sqft house, 24X32 pole barn, hot tub @ 104 degrees, all domestic hot water, and in summer I heat my 45,000 gal inground pool. I'm pretty sure that my CB is rated @ 500,000 btu but take ANY boiler's ratings with a grain of salt. I put (not fill) wood in it twice a day when winter sets in. I could fill it once a day but I get better burns doing it twice. I burn about 10 full cords a year not counting the pool. I just started heating the pool in Nov and only for a few weeks so I don't have a good count on that yet, but I can already tell I will be burning a "bunch". During last summer just heating the hot tub and DHW, I would only use about a wheel barrow full every 2 days, so, I don't feel you will burn more wood than you need to until you put your pole barn on. It will only need to produce heat to cover the load you put on it. It is also my opinion that a unit that holds more water will work better in keeping boiler temps up. My old boiler only held 175 gallons of water and always struggled but my CB holds just shy of 400 gal and never has a problem.
Rule of thumb.....see what size they recommend for your application and buy 1 larger.
What is nice about the non-gasser OWB is that if it fits through the door, you can burn it. Makes wood prep so much nicer. All the uglies, knots, Y's that would get "hung up" in a gasser are no problem burning. I had a OWB gasser so I know first hand. Yes, if you have any close neighbors you may run into trouble with smoke, but I have seen indoor wood stoves that smoke just as much as me during start up.....and there is NO law against them. As always, the drier the wood the better your results will be.
Whatever boiler you choose, DO NOT skimp on the underground piping! Pay the money up front and save yourself from headaches down the road.
Although this site is an awsome source of information, most of the folks here are not OWB "friendly" so to say, so you will probably get several "Smoke Dragon" comments.
Another great source of info "mostly" on Outdoor Boilers can be found here:
http://www.outdoorwoodfurnaceinfo.com/forum/
One thing we all enjoy is NOT seeing the fuel man!
