I'm building a home on a slab foundation. I will have a PE Super 27 wood stove and desire to have outside air for combustion. I believe the house will be sealed tight enough that it is a necessity. The stove will have a chimney pipe that will be about 21 feet high.
I had proposed that we run the outside air supply line down from under the stove pedestal, under the slab, through the foundation wall, and emerge outside the house.
My contractor has proposed that we run the line to the back of the stove, into the wall, then up to the attic and out the gable. The would make the pipe run 8 feet up from the entry to the stove, then sideways 25 feet to exit the house at an elevation of about 9 feet. The line would be covered with significant blown cellulose insulation as it runs through the attic.
Are there problems with this method of supply? Why not just have the supply pipe extend above the insulation in the attic and skip running it horizontally to the gable? The wood stove will not be the main source of heat, so should I add a damper to shut if off when the stove is not in use to prevent air infiltration through the make up air line?
Appreciate your thoughts.
